school me on 97' 883 Hugger also help me cutomize with the right parts/links
I just wanted to start a thread that I can ask for the right parts and get Ideas for my bike and refer back to and evolve as I go. Thanks ahead for any input.
Honestly, I know there's a lot of them but I really like the nightsters and I REALLY like the nightster/bobber/customs that I'm seeing a lot of on here, so I'm trying to learn a little on my hugger and what parts I need to make it more like a nightster/custom.
:Is the hugger's frame geometry any different than other sportsters?
:Are the front fork tubes the same length as the nightsters? They sure look like they are from eying pics..
:Rear shocks on hugger are probably just Drop'd 2" ?
: whatever else you guys can school me on about the hugger
Here's my Winter customize Wish list, Depending on Money of coarse.
:1250 Cylinder upgrade kit from NRHS, Prolly the first thing I'll do.
:Return Front end back to Sportster Triple trees. Where to buy the Trees? do I need a new stem/bearings as well?
: Different old/school, Cool looking headlamp and front turn signals.
:Either Drag/riser bars or stock riser bars flipped? Maybe black mini apes like I have??
:what handle bar controls do you guys recommend?
:Maybe change pipes
:Mid/stock foot controls
: Different/chopped rear fender
: Different Solo Seat
Current bike pics
Current state. Replaced Handlebars/Hand controls/headlight/triple trees. Painted lower forks.
:Maybe change pipes
Current bike pics
Man, That is a bad *** looking bike already! I really dig the white walls.
Anyway, What front end is on it if it is not stock?
aftermarket handlebar controls are EXPENSIVE! Most people stick with stock or just chrome covers.
If you go back to mid controls, you will have to change the pipes. PM me if you do, I want those pipes!
You can always paint your bars black if you want. Drag bars are a completely different ride and feel all the way around. You will also have to change all the cables if you do, the existing will be too long. Bars are a personal preference. For me it's apes and I will never go back!
Definitely do the 1250 kit!
I like your headlight, I would keep it and see how the rest goes first, Loose the front signals,it really cleans up the forks/front end and learn your hand signals.
Thanks Wood.
The front end has Wide glide triple trees and spacers for the fender. I dont plan on going with a wide tire(for now) so I just want the stock trees.. I found these on ebay, they are from a 09' will they work?
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
I like the pipes too but they stick out quite a bit and cover up the mid controls(obviously)
I do like the mini apes, they are surprisingly comfortable. Not sure on change out on those yet.
Not sure if I can rid the front turns? is it legal in WA state?
Yeah but I don't know if yours is lowered. It looks like it is...so it's pretty similar to a Nightster. The difference wetween your tubes and a Nightster's are very minimal. Like, axle size (later model N's) and the caliper mount is a little different but the overall appearance is the same.
You need trees from a Sportster 03 or older. Where are you located?
ya the length of the tubes seems very close to the nightsters. I will need a new axle when I switch back to the stock trees too so that helps on the size.
I am in Spokane WA.
Would you sell your parts?
How do you like those pipes? are they extra loud from echoing off the ground too? It looks like you could use mid or forward controls with them?
