How to tell a 883 with a 1200 conversion kit?
without paperwork or ripping it apart, you'll have to make an educated guess. of course the 1200 will outperform the stock 883 by a noticeable difference, BUT...the difference narrows if the 883 has a stage one and agood tune. You'd need to be pretty familiar with the overall output on an 883 to know for sure with a "seat of the pants" measurement. The other option would be to dyno it
As for it "running" better...not necessarily. it'll just have more power. Physically, they are the exact same bike, even the cans. the 1200's are just bored bigger. there is differences in the gearing, but you can't see that, and it wouldn't likely have been changed with a big bore kit.
I read this:
1. Add 300 ml ethylene glycol to 300 ml Dot 5 brake fluid
2. Remove the rear cyl spark plug
3. Insert a wooden or plastic probe
4. With the motor in top gear use the rear wheel to rotate
the motor until the probe shows bottom dead center
5. Elevate the rear wheel by 0.76 meters
6. Carefully pour the fluid mixture into the spark plug hole
7. If you use it all up your bike is a 1200. If there is
158.5 ml left over then it's an 883.
