Mini Apes to Drag bars (part 1)
Old 01-02-2011, 03:27 PM
Murph918's Avatar
Murph918
Murph918 is offline
Default Mini Apes to Drag bars (part 1)
Some pictures of me swapping out my mini apes for drag bars.
Bike as I bought it in Sept 10.
Inspection cover removed
Removing lock nut
Pulling out Ramp assembly
I had the bike jacked to keep straight, I thought there would be a lot more fluid coming out of the inspection cover.
Old 01-02-2011, 03:32 PM
Murph918's Avatar
Murph918
Murph918 is offline
Default Mini Apes to Drag bars (part 2)
Mini Apes to Drag bars (part 1)-18-reinstalling-primary-cover-with-blue-loctite.jpg
Old 01-02-2011, 03:37 PM
Murph918's Avatar
Murph918
Murph918 is offline
Default Mini Apes to Drag bars (part 3)
I had pulled on the air filter (fortunately not forcing) not realizing there were 2 more bolts under the rubber spacer
Old 01-02-2011, 03:43 PM
Murph918's Avatar
Murph918
Murph918 is offline
Default Mini Apes to Drag bars (part 4)
The Breather screws took a little more force than I thought they would take at first
Getting ready to remove the tank
Old 01-02-2011, 03:50 PM
Murph918's Avatar
Murph918
Murph918 is offline
Default Mini Apes to Drag bars (part 5)
Brass tube came out of the Fuel cut off switch, this was not expected
Mini Apes to Drag bars (part 1)-30-fuel-stop-cock-tube-out-not-planned-on-.jpg
Old 01-02-2011, 03:55 PM
Murph918's Avatar
Murph918
Murph918 is offline
Default Mini Apes to Drag bars (part 6)
Mini Apes to Drag bars (part 1)-34-deinstallation-of-idle-control-cable-with-spring-.jpg
Got a tip from local Bike Shop saying to loosen banjo bolt while bar is still tight. Good tip!
Mini Apes to Drag bars (part 1)-34.1-loosen-banjo-bolt-while-handle-bars-are-still-tight.jpg
Stripped allen screw
Old 01-02-2011, 04:02 PM
Murph918's Avatar
Murph918
Murph918 is offline
Default Mini Apes to Drag bars (part 7)
Mini Apes to Drag bars (part 1)-38-using-easy-out-to-remove-stripped-allen.jpg
Busted eay out, should've been more patient and gone with a much bigger easy out
Mini Apes to Drag bars (part 1)-39-busted-easy-out-should-ve-gone-bigger.jpg
Mini Apes to Drag bars (part 1)-40-removing-riser-with-bars-to-take-to-shop.jpg
After a lot of drilling and beating on the busted easy out I took off the riser with the bar attached and took to "Pete G's Chopper Design" in Longwood Florida for help taking the stripped allen out.
Great bunch of guys!
Old 01-02-2011, 04:07 PM
Murph918's Avatar
Murph918
Murph918 is offline
Default Mini Apes to Drag bars (part 8)
Mini Apes to Drag bars (part 1)-43-drag-bars-installed-with-controls-and-old-cables-still-on.jpg
Mini Apes to Drag bars (part 1)-44-using-screw-driver-to-assist-cable-install.jpg
Micro bubbles in front brake master cylinder
Old 01-02-2011, 04:10 PM
Murph918's Avatar
Murph918
Murph918 is offline
Default Mini Apes to Drag bars (part 9)
Before
After
Comfortable riding position
Old 01-02-2011, 04:51 PM
kahaone's Avatar
kahaone
kahaone is offline
Looks much better this way. Apes and the those "C" stock risers just don't match, and it looks ridiculous. It looks much better now! The risers actually seem to compliment the drag bars. I never did like those risers much, but, they do look good with those bars on!!
Quick Reply: Mini Apes to Drag bars (part 1)
