just put the leads on,for a battery tender.
there is a little cover right by the battery box with 3 screws in it,
what is the right way to take it of and put it back on,and yes i will get a
manual best advice ever.
thanks
thanks
Just unscrew it. mine came off easy except for one bolt...it was a bitch and stuck to the rubber so i just pulled it out and fixed it once it was off.
send me a pm with your e-mail i have a online version of a manual (pdf)
You don't need to undo those three screws. You just pull on the cover, as the three screws are attached to rubber gromets/nipples that just pop in & out of the holes for quick access to your fuse panel.
