Sporty custom apehanger problems
I tried to find a previous post on my problem and couldnt, so sorry if there is one. I have an 03 custom, it had dragbars with 6inch risers on it when I got it. So recently I bought the burly 12 mini apes and wire/cable kit. Well after starting the install I realized that inside my riser covers there is a ton of electrical plugs/wires. Then I realized that even if I was able to get all of the wireing and connectors out of there that my indicator light strip wiring will be showing and open to the elements. Then I noticed that if I drop my risers down any lower my speedo will be hitting the tank. With the six inch risers there is only about a half an inch from speedo bottom to tank. I have the set up where the tach. Is mounted to the top clamp as well. This is my first time working on a bike and it figures I had to get the one sportster model that doesnt like to except apes. I have never ridden a bike with apes on it, but when I sit on the bike my fists are about as high as my eyes. I assume that will be very uncomfortable right? I would love to just leave the risers the way they are to avoid all of the bs, but I want to beable to ride it too.
His risers aren't stock curved. They're stock straight. 03 was the last year for that.
What I've done in the past was thin the pack out and put the plugs beneath the tank where they are on the 04's & up. I've also extended the wiring down to the headlight bucket where all that crap is on the non-"C" models. It's a mess in there.
You can use that same top riser clamp to retain your indicator lights.
Yes, it is water resistant. You can put the harness plugs in the headlight bucket and run wires in a loom out to wherever they go so it looks better and helps prevent exposure to the elements.
The speedo can be mounted where the tach goes. You can also buy a bracket to mount it where your upper triple tree fascia bolts.
This is an 09 "C" model I did a while back. The wiring is different but the risers are similar (but curved) and speedo is similar. Close enough to give you an idea.
Stock with drag bars
I used individual shorty risers and made a bracket for the indicator lights
I made a bracket to mount the speedo to the upper tree fascia
I mounted the speedo unit (same as yours) in a chrome gauge bucket I got from Jegs.com that bucket bolts to the bracket I bolted to the upper tree fascia.
And here it is all together
This may not be the look you are going for but the "job" itself is the same.
Here's a thread on it. I think there's a video in there somewhere.
https://www.hdforums.com/forum/sport...ugly-pipe.html
