Iron 883 with peculiar problem.....driving me nuts
I have a 2009 iron 883, i bought it 4 or 5 months ago stock with 2300 miles. It ran great, ive since put on vance and hines shortshots, a heavy breather, and a vance and hines fuelpak. i have had no problems whatsoever with the vance and hines pipes and fuelpak. i did not have the heavy breather to due backorder issues but i recieved it this week and put it on and everything went fine. I took it out for a drive today and everything was fine. On my way home after my stop i got to my house and shifted down to first to pull into my drive way and it made a wierd noise kind of like down shifting to brake at a stop light or whatever but it did it whenever i pulled in the clutch fully. So i didnt think anything of it at the time but i tried to turn off the bike next and clicked the off switch and it wouldnt go off. It just kept making a chugging noise but would not go off. I had to turn the key to get it to go off. Then i tried to restart it and just turning the key into the run position made the bike try to startup. Then i turned it to on and started it up fully and tried to ride down the street and back. I did and when i pulled in the clutch fully it made the same noise but i noticed the headlight dimmed also when i pulled in the clutch fully...after that, same as before. would not go off and when i turn the key to run(even in off) it starts with the chugging noise trying to start....SO i took out the fuelpak thinking it was something maybe with that but it did it with stock config also..... What the heck is going on.....
btw, when you change the sucker you should also change the fuel settings- but first you want to be sure that your fuel management system is working. if it is, and adjustment to it could be the solution.
What you are saying is that as soon as you turn your key on, the starter runs? If that is the case either your starter relay has welded contacts, or you have something wrong in the wiring somewhere (pinched wires). Check your relay first. You can swap it out with another one on the bike and see if it still does it.
To wanabe, i have the correct mapping for my setup in the fuelpak but even when i uninstalled it i had the same issue with startup and so i eliminated it as the "cause". also i am running premium gas
To Gpsjr10, yes as soon as i turn the key it tries to start(though it sounds a little different that normal starting or running),i was leaning toward the pinched wire idea, the only other thing ive done recently is wash it yesterday, maybe water got into the sealed cavity somehow.though The fact that it dims the light when i pull the clutch may mean its around that area.
General question, there is a 24 month warranty on this year and model correct?(assuming i can get them to honor it)
....thanks for the help
I agree with Gpsjr10. I'd put my money on it being either one or both of the relays since the problem showed up after washing your bike.
The '07-'09 fuse block is vulnerable to water running down into it causing corrosion of the fuses, relays and fuse blades on the block.
Do a search on this forum (and others) for the words: wash and relay. Then do a search on the words: swap and relay.
Yes, since you washed it, I'd pull the entire run/start/stop switch assembly apart and blow it dry with compressed air or a hair dryer.
Water in that switch housing could be shorting the start button.
When I wash my bikes, I do it with a squirt bottle and a wet towel. I don't spray it with a hose ever. I've had water get places from washing with a hose that it could never get from having been ridden in the rain.
Isai Martinez
07-12-2022 07:36 AM
