High Idle, Bad Gas Mileage, fouled plugs
Recently installed v/h shortshots and PCV on 2010 Sportster 1200C. After the install I noticed very high idle and horrible gas mileage. I changed the map which helped the high idle a little but my gas mileage went down to 20mpg. Also, my plugs keep fouling. the map change should have solved the rich mix, but i am still having problems. Any suggestions?
Air cleaner is stock.
I talked to fuel moto and they advised me to make some adjustments on my own. Atleast to get the idle down anyways. I pulled the air cleaner and I am letting it dry out a little. I also going to try the computer idle reset. If this doesnt work I am going to pull some fuses hoping for a reset. I am assuming the leaner I get the mix the lower my idle will be?
My bike is due for its 1000 mile next week, not sure if the stealer willhelp me out or not. As far as power commander goes, I have no faith in them.
Many, many, many people use the Power Commander's and have absolutely no issues with them. However, it could have something to do with the installer, and whomever actually did the mapping input and adjustments. Or, possibly you do have a bad unit.
Persoanlly, I have a Power Commander wit5h no problems. Mine was installed and dyno'd by a local indy shop. The dyno is what is really needed to tune it properly.
Funny story:
I decided to take the pcv off to see if the bike ran ok without. Once the pcv was off the bike wouldnt turn over. After giving her a little gas she spit a bunch of white and black smoke out. The idle was aweful and bike acted like it was going vomit and started convulsing. after trying to start her for 20 min the battery is dead now. All I get is the dreaded click. I am throwing codes related to the O2 sensors. I better just haul this piece to the stealer and say......I have no idea what happened, which in actual terms i really dont. This blows
