Old School narrow springer!
I picked up this old school 7/8" neck narrow springer a while back.
Pressed the 1" neck out of an old tree.
Removed the 7/8" neck from the springer, enlarged the holes to accomodate the 1" neck and now I need to make some old school bars to compliment my kick *** springer!
I think I might shorten the legs a couple of inches but right now I'm just diggin it!
Thanks!
Thanks!
Ha ha...nope! Check out what I did with these old bars...
Started with a brand new set of humongous apes that have been hanging above my compressor forever, marked cut lines & separated the pieces I want from it.
[IMG][/IMG]
[IMG][/IMG]
I wanted to bend them forward & keep the 12" tall but when I test fit them I realized I'm partial to short bars.
Here they are cut to the final length & drilled to plug weld.
[IMG][/IMG]
This may be fopaux but I've gone this route in a similar fastener application and it holds up well as long as you understand the material...all thread connectors as slug bungs.
[IMG][/IMG]
I had to taper the ends to get them flush with the bottoms of the bars.
[IMG][/IMG]
Welded in
[IMG][/IMG]
Cleaned em up (threads included)
[IMG][/IMG]
Made a template
[IMG][/IMG]
Made the piece
[IMG][/IMG]
Welded it in & drilled holes
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
This worked well as a headlight mount on my drop seat and I'm using a similar headlight. It's a front transverse leaf spring shackle I use on late 20's frame builds.
[IMG][/IMG]
Bolted up with the headlight stand-off attached
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Welded in
[IMG][/IMG]
[IMG][/IMG]
Made a template
[IMG][/IMG]
Made the piece
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
