Hi Craig,
do you know the measures of the DK mount bracket (relocation ignition key)?
Do you change the ground screw/bolt to mount the bracket?
Thanks
Luca
Hey Luca,
Sorry, I sold that bike some years ago and can’t quite remember. I would contact DK Customs. Their products are awesome and so is customer service. It should be easy and apparent to you if you do need to do anything once you get ready to install.
Hi all,
what are measures of the DK bracket?
Do you change the ground screw (longer screw) to mount the bracket?
thanks
Luca
If you are asking about mounting the F6 Ignition Relocation...NO, you do not need to change the stud on the primary to mount the F6 there. The exception to that is on Sportys that are 2003 and earlier. There are notes and photo's at this LINK.
And you can see a PDF of the instructions at this LINK.
I mounted my stock sportster 72 horn between the down tubes by not using the chrome cow bell cover and making my own bracket. It's a tight fit but worth it to have the sound of the original horn instead of the smaller cheaper sounding horns. It can be done
I definitely need to remove that sound as well.
but after riding choppers with no horn most my life STILL after finally getting 1st geezer bike in 2015 have yet to use horn as instincts is pull in clutch and WOT🤣🤦♂️🤷♂️
