sportster 48 tank lift???
Received 3,940 Likes
We've done dozens and it depends on how tall a tank lift. We have 1.5", 2", 2.5", and 3".
Usable capacity is reduced by 1/8 to 1/4 gallon...so maybe 5-10 miles of total range if you run to bone dry.
This LINK has more info on the subject.
Kevin
Kevin
Want tank lift for my 91, but didn't even take into account that you lose mileage. I guess it's because the angle is changed therefore losing mileage. Hmmmm.
There isn't a way to do the "lift" and keep the angle so fuel mileage remains the same? Or is it that it doesn't look "right" keeping it angled?
I know that DK said that with a 1.5" lift, which is enough to tuck the wires between the tank and frame rail, you only lose 1/8 of a gallon on the 3.3gal tank, not sure if that number would apply to the 2.1 gal tank on the 48.
Now, keep in mind that if a wire tuck is your goal, there are two things to keep in mind:
1) On the 48, you can get the wires in between the tank and frame rail with no lift. Many people have done this and posted about it.
2) On the 3.3 gallon tank (iron, nightster), you can do what I did, and hide the wires below the frame rail, without a lift:
https://www.hdforums.com/forum/sport...k-no-lift.html
