Info on 48 front-ends
Got a 2007 883L I want to turn into a 48 lookalike with a 16" front wheel. Are the 48's a wide glide or mid-glide? Does anyone make a conversion kit to do this?
they are more like a mid glide. Not sure if there is a conversion kit out yet?
They are mid glides. I have seen a few MG trees, but are about the same price as factory trees, which will run you in the $250 range for the upper,just under $300 for the upper.
please look into the following link... good info:
https://www.hdforums.com/forum/sport...-end-work.html |
Thanks guys! Check out this link if you have time and advise me if I have the correct kit selected... http://vulcanworks.net/store_4/produ...&cat=11&page=2
This kit which is a mid-glide makes no mention of a 16" wheel... http://vulcanworks.net/store_4/produ...&cat=11&page=3 This will be used on a 2007 883L with the pictured tins. http://i434.photobucket.com/albums/q...ortster005.jpg http://i434.photobucket.com/albums/q...ortster006.jpg http://i434.photobucket.com/albums/q...ortster007.jpg http://i434.photobucket.com/albums/q...ortster008.jpg |
Originally Posted by rickss69
(Post 9007717)
This will be used on a 2007 883L with the pictured tins. http://i434.photobucket.com/albums/q...ortster004.jpg |
Don't think the legs are chrome (bike not in hand until next week), but I may swap out the lowers while I'm at it. The mid-glide kit does not have an option for the 16" wheel???
If I read correctly the 2007 has a 3/4" axle while the 2008 - up use a 1" axle. May be hard to find chrome lower legs for this 2007...or could I change the conversion kit to a 2008 - up and buy some newer lowers? Like these maybe... http://www.ebay.com/itm/Harley-Chrom...sories&vxp=mtr |
Unfortunately that kit will not work. Your bike has 41mm forks, that is for older Sportsters.
Originally Posted by TennesseeMustangPerf
(Post 9007836)
EDIT: Confirmed from Vulcan they are indeed 39mm forks. |
(Post 9007757)
If I read correctly the 2007 has a 3/4" axle while the 2008 - up use a 1" axle. May be hard to find chrome lower legs for this 2007...or could I change the conversion kit to a 2008 - up and buy some newer lowers? Like these maybe... http://www.ebay.com/itm/Harley-Chrom...sories&vxp=mtr https://www.hdforums.com/forum/sport...id-struts.html so how come the 48 comes with a fat 16'' front wheel on a mid glide configuration... well.. I am willing to bet that the 48 front wheel is like the one MREED made.. (correct me if I am wrong please..) Some more info: https://www.hdforums.com/forum/sport...-up-front.html
(Post 9007901)
You are saying the 2007 883L has 41mm forks??? Why do all the kits state clearly what years they fit? Everything I'm seeing so far says 39mm.
© 2024 MH Sub I, LLC dba Internet Brands
