How do I adjust idle on 2007 Sportster w/ fuel injection?
Contrary to prior posts, your ECM cannot adjust to the new high flow mufflers in all but the very narrowest sense. Seriously, the range of adjustment is not large enough to accomodate the change in air flow. When we change these types of things on an injected engine, there is a corresponding lookup table (commonly referred to as the "map") that needs to be adjusted. That is done with a device known as a tuner, and there are many available for Sportsters. It is the same thing that is done with the "stage 1 download" from your local stealer. The same tuner will allow adjustment of the idle, but other than that, and perhaps that little device referred to earlier, you're out of luck, as the ECM will do whatever it takes to achieve the pre-programmed idle parameters. As far as it knows, the idle hasn't changed, even though you know it has. It is trying to create the exact conditions it is programmed for, and it isn't reading (as far as I know) the crankshaft revolutions exclusively in determining idle.
The engine is a simple air pump....increasing the capacity to evacute air from the engine doesn't allow more air to enter it (which is what a tuner is all about....increasing the amount of fuel delivered to correct the A/F ratio) unless you can prove to me that the exhaust is more restrictive then the stock intake. There might be dyno's out there to prove this. Which even if it is....is probably only marginally which the ECM can adjust.
Maybe you are making the assumption that the OP has a high flow intake like a stage 1 or Arlen Ness super sucker where I am thinking he just stated that he removed the baffles from his muffler and my assumption is he is otherwise stock.
We both could be wrong depending on his set-up. If he does have a high flow intake and running screamin eagle slip-on's then I agree. However, he should have had a tuner or remap on it already in that case or he is running very lean!
There are numerous people out there who buy their performance exhaust before the intake because they can't afford to buy the exhaust, high flow intake and fuel mgt system all at once. So the default answer is to buy the exhaust first, fuel mgt system second or with the high flow intake but to never put the exhaust and intake on w/o a air/fuel mgt system. I have yet to hear from any issues running this way since I got my EFI sporty in 07'.
What change in air flow?
Your recommended recipe of buying exhaust first, fueler next, then the a/c is typically sufficient - but not necessarily so. The OP might just find everything runs fine at other than idle - remember we're talking idle here at the moment. The idle system is a bit different in that there is an iac valve that steps open and closed to allow idle air in, (in fact there is a separate map for idle).
However - all this aside (both mine and yours), something changed in order to affect the idle. You posited that there isn't enough change in exhaust alone, if true - then what affected his idle? BTW, the OP never mentioned changing the intake - and I didn't factor it into my comments.
Right - and this makes sense to me, the mixture is leaner and the ecm is doing something to try to compensate. Exactly what, I don't know. Too many different maps in use for idle control, I'm not that good at this.
Please read... (note though that this does not discuss the addition of O2 sensors)
http://community.jpcycles.com/articl...ion-espfi.aspx
That is the part that makes me wonder. My bike has O2 sensors and if they are not mentioned or used, why is it there?
Open Loop - The ECM monitors sensors positioned on the intake side of the engine and does not monitor the end result of internal combustion at the exhaust.
Many of the piggyback tuners commonly used on our bikes actually disconnect the O2 sensors because what they do is fake the reading going to the ecm so that it thinks the bike needs more fuel. For example, they might tell the factory ecm that the engine is cold (adds fuel), or that it is running lean (adds fuel).
I'm not an expert at this, but I read a lot!
Idle
Hello and thanks for the info, however, I am still at a loss as I have been told by many that just changing to a straight through exhaust will not require a remap for any reason. There are no other changes other than the removal of the entire baffle on the Screamin Eagle mufflers. I am aware of the factory throttle blade stop screw and may make an adjustment to this to see the effects. I have searched for a factory setting dimension for the throttle blade open amount and am sure someone knows this. I would like to know what the setting dimension range is from the blade to the throttle bore at idle position, anyone out there know? It's hard to believe it would cost an arm and a leg to have an adjustment made to change idle speed. I thought we are supposed to be moving forward with new technology but it seems like the technology is a way to scavenge money. Thanks for any info you guys can give me.
