I can't post a pic but if you google ( main fuse buell ) you will see the little box your
looking for,because it sure sounds like your main fuse is blown.
I dont know why I cant find this main fuse (haha maybe thats my problem :P ). Would it be located between the starter and the circuit breaker? Or between the battery and starter? Maybe I'm looking in the wrong place.
You have to take the front cover on the gas tank off,setting on the bike it's on
the right side when you lift the cover off you will see it
let us know how you make out
Good luck
or google (main fuse buell youtube ) and watch the video
I just looked at a pic of a Buell wiring diagram and I see where there is a circuit breaker in the circuit. Does the wire that goes to the circuit breaker have an eye connector the same size as the battery cable? I think maybe that the wire going to the battery and the wire that goes to the circuit breaker should be on the same terminal on the starter. (Arrow 1) Then you will have power to the Circuit breaker (Arrow 2) Guess there is no main fuse. I didn't realize the Buell wiring was that much different from the Sportster.
I have the same problem, I changed handle bars and at first I had power to everything, then I tried to start the bike again, and now I don't have nothing to the dash, no light, nothing, I checked all the fuses, and none are blown...I have a 2010 Street Glide
2009 Harley Sportster nightster XL1200
I changed handlebars too, but that was a month and a half ago. I rode the bike on Wednesday; everything was copacetic. Then tried to start it on Friday and nothing. No power whatsoever. Battery has been tested and it's good.
