Wheel swap question????
Sportster front axles are:
'04 thru '07 3/4"
'08 and up 25mm
Wheel hubs should all be the same. Forks will take whatever axle you have from your original bike. You can change (or have changed) bearings to match whichever axle your bike has on whatever wheel you choose.
'04 thru '07 3/4"
'08 and up 25mm
Saw this thread got bumped. Never did it yet. I just got a 1250 kit and quarter fairing and chin spoiler so the wheels are gonna have to wait. I did notice though that on the super low the triples are noticeably wider. So do make it easier of a swap, might just do the triples wheels and spacers with the iron fork tubes.
Im bumping this thread again. It looks like superlow wheels will fit onto an iron. You will need mid glide trees/superlow or 48 to complete the conversion
http://xlforum.net/vbportal/forums/s....php?t=1675941
Yes, I did it recently on mine... https://www.hdforums.com/forum/sport...ghtymouse.html
The rear is no problem, but the front will require a change to a mid glide. A little pricey, but if it's what you really want a worthy effort. Mine is a '07 and I opted to stick with the 1' rear and 3/4" front axles which presented extra problems...those with 25mm hardware will find it fairly simple.
