Plug Wires - What Size
Almost all the stock wires are 8mm. Like was said before, if the length is under 12" or so, it doesn't make that much of a difference. The bigger diameter is just more insulation, which leads to a stronger spark because the voltage leak-off is not as much.
For the average rider, it's not a big difference. If you want the peak power and performance, you can get some better ones.
Received 3,939 Likes
Stock wires are 8mm
Most Screamin' Eagle wires are 10mm
Some of the older SE Wires are 8mm
PRO RACE wires are 10.4mm
The core of the wire and then the connectors are probably the most important factors in getting good spark.
I have noticed a difference in going from stock wires to the SE or Pro Race, BUT in each case it was from USED stock to NEW SE or PRO RACE. Wire core, connections and insulation all degrade with time, resulting in a weaker spark.
The all USA made Taylor PRO RACE will take longer to degrade than the stock or SE wires.
I swapped out plugs and wires from stock to SE on my '11 103 RG and it didn't idle as well?
The HD mechanic told me the internal resistance was different and the motor was designed and tuned with the stock stuff.
So what is the story on differences in the resistance here and am I just blowing money for nothing more appearances?
Lost
I got Hi 4N ignition and the 3 ohm coil looks stock. Got lost replacing the spark plug wires with ones with a 90 degree angle plugging into the coil. That looked nice. It did not last. Had to check the ignition to see why the engine would not run right. It is just that while checking the ignition top dead centre the spark plugs got pulled. It helped find the problem when the plug that goes into the coil came off the wire. I got to decide which way to plug into the coil.
