Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   Sportster Models (https://www.hdforums.com/forum/sportster-models-10/)
-   -   2007 1200 sportster won't start (https://www.hdforums.com/forum/sportster-models/750851-2007-1200-sportster-wont-start.html)
Alexg13 Apr 1, 2012 03:32 PM
So guys I turn the key all lights go on except the odometer click the run switch I hear the fuel pump and then I click start and nothing no sound at all. I changed the battery and the battery in my key fob still the same thing! Please if anyone can help I would be very thankful!
Thanks to all in advance!!
cHarley Apr 1, 2012 03:48 PM
07's are notorious for getting water & corrosion in the fuse block area.
Remove all fuses and the 2 relays, test the fuses for continuity with a meter, clean their contacts, coat the contacts with dielectric grease and reinstall.
Alexg13 Apr 8, 2012 02:57 PM
Thank you it was a fuse
Matthew Householder Apr 30, 2019 09:38 PM
Same problem just bought the bike.
Took all fuses and relays out. Brand new battery even tried jumping with a starter box incase battery wasn't enough new. Still everything turns on pumps lights and relay just clicks everything is ohming out 12.4 volts on the battery. What should I use on fuse and relay sockets?
handirifle May 4, 2019 12:04 AM
12.4 is actually low for a 12v battery. That puts the battery at about 50% state of charge. Throw a charger on the battery. Did you check the battery ground connection on the frame? Folks here say they are prone to corrosion.
Dielectric grease is what you use on elec terminal connections. Keeps moisture off the connectors.
Matthew Householder May 4, 2019 02:18 AM
Hello and Thank you..
It was the starter relay. I swapped the system relay with the starter and it cranked but wouldn't start. So I bought a relay and boom she fired right up
handirifle May 4, 2019 09:06 AM
Thats using the old noodle. Glad ya figured it out.
© 2026 MH Sub I, LLC dba Internet Brands
