Whining noise
Yeah I did the same thing. Fired it up after work and it was doing it. Stopped to top off and fired ot back up, not a peep.
I have the same issue with my '07 1200C that started 3 weeks ago. The difference with my situation is the noise starts while it's priming the fuel pump and it continues until I shut the bike off. The other difference is it only happens when it's hot outside. Early morning commutes and late evening rides are fine.
Fuel level doesn't seem to make any difference in my case - only the outside temperature.
However when I went out to get gas (it was still probably in the mid to upper 90's) I definitely did hear the whine, then I got gas and there was no whine.
I have noticed my MPGs are down a bit as well.
One of the gurus over at XLForums posted a link for "Tech Tip 328" which covers the Regulator Spacer Kit (#61005-07) - https://www.box.com/s/6g6czdcjxy2vkq4ys324
