how to shorten rear lights???
It is easier once you shop your rear fender however, if you are keeping everything else stock, it can be a little tricky. Once you take the "arm" off of the tailight the actual tailight itself will not mount flat onto the strut because the housging is angled, if that makes any sense. A lot of people just mount it ias close as they. HD makes a kit that that comes with a plastic piece so you can mount it like you want however, it does not have a hole for the electrical. You would need to get hollow bolts so you can run the wiring through. Somewhat of a pain. I tried all of this and in the end I purchased new tailights that mounted directly to the struts and were smaller. Sucked because it was kind of pricey. If you can makes it work with the stock tailights and be happy with the outcome I would recommend it.
These are the standoffs from a Softail. They're 3/4" shorter. The short ones are on 200mm tire bikes. '06 was the first year for the 200 rear.
These were powder coated gloss black (over chrome, before Harley had black units) by FigureFinishing.com
The detachable docking hardware barely fits, but it'll go. Here's a mock-up with hardware and shorty standoffs I did for another thread:
hi there take a look at this thread , youll see some good ideas there , including my $4.00 signal relocation .
https://www.hdforums.com/forum/sport...ation-kit.html
hope this helps , ride safe , ride often
Hey Dafy that looks pretty awesome, I've been wanting to get the shorter stalks for a while but your way might work well too. Did you just fab up a bracket yourself out of flat stock?
