rear tire size??????? ??? ??
Old 01-14-2007, 10:05 PM
cajun883custom's Avatar
cajun883custom
cajun883custom is offline
Default rear tire size??????? ??? ??
just ordered a custom rear rim to match my front
18x3.50
my question to yall out there in sportster land,
what would be my best bet for tire size, 150 or 160mm?
and also, what complete size,, like 150/70 18?
Old 01-14-2007, 10:35 PM
OldFenderGuy's Avatar
OldFenderGuy
OldFenderGuy is offline
Default RE: rear tire size??????? ??? ??
ORIGINAL: cajun883custom
18x3.50
Sounds like a winner to me....
The maximum recommended size for the rear of the Sportsters (without any modifications) is 18 X 4.25 with a 150/70 - 18 tire, so the 18 X 3.50 will work without any problems.
Don't know if I would try going with a 160 tire, as that would be pretty wide for your 3.50 rim, and that would be over the recommended size anyway.
As far as tire sizes, the 150/70 -18 would probably be your best bet.
Just for information; The 140/70 - 18 tire is recommended for rim sizes 3.00 - 4.50, and the 150/70 -18 is recommended for rim sizes 3.50 - 4.50..
Old 01-16-2007, 02:01 AM
brauny1's Avatar
brauny1
brauny1 is offline
I want a widerrear tire, and every time, they tell me the 130/90-16 is what I gota live withon the T16x3.00 D rim. I do think the tire runs very close to the drive belt. BUT... How isyour new rim and tire working??? I'd really like to know...
Old 01-16-2007, 11:35 AM
cajun883custom
ORIGINAL: OldFenderGuy
18x3.50
Thats actually the size I found somewhere on the internet. Thanks a bunch. Rather be safe with the 150 than buy a 160 and be screwed if it doesnt fit.
Old 01-16-2007, 12:25 PM
slammedsporty04's Avatar
slammedsporty04
slammedsporty04 is offline
so when do you expect to get your wheel and tire. I am kinda interest to see what it will look like, something I might eventually want to do. can't wait to see what it will look like.
Old 01-16-2007, 04:49 PM
rx3732's Avatar
rx3732
rx3732 is offline
I've got a 160 Metzler on mine w/ no problems whatsoever. Same bike as yours, '06 883C.
Old 01-16-2007, 05:42 PM
cajun883custom
ORIGINAL: rx3732
what size tire? what size wheel you have in rear? marathon tire?
Old 01-16-2007, 05:51 PM
OldFenderGuy
Not all tires are created the same..
Depending on manufacturer there can be a sizeabledifference in actual tire width, from one 150mm or 160mm tire to another. The sizing isn't as 'standard' as you might think.
A 160mm tire from one company might not have an actual width any greater than a 150mm tire from another company.
If you are talking close tolerances I'd be very careful and take some measurements when considering 150mm/160mm tires from different firms.
Old 01-16-2007, 07:54 PM
rx3732's Avatar
rx3732
rx3732 is offline
ORIGINAL: rx3732
Yes, it was a marathon tire. 16" on the factory wheel.
And OFG is right, not all are created equal. But if you check out Metzlers website, they list what max tire size you can fit on your make/model of bike. I've read where several people have gone w/ the 160 on the rear as well before I made the decision. Check out my picture in my profile...I have a 'rear' shot showing the tire. I HIGHLY recommend the Metz Marathons. Great tires!
Old 01-16-2007, 11:22 PM
slammedsporty04
yeah a lot of people are running a 160 on the factory 16" wheel. but you need to remember he is not going to be using a 16" wheel, he order an aftermarket 18" which may be different. I would play it safe and go with the 150 this time.
Quick Reply: rear tire size??????? ??? ??
