Anyone running a velocity stack w/EFI Sportster?
The bar end mirrors are Oberon 7/8" bar end mirrors. I bored a 11/16" hole (same I.D. as a 7/8" steel handlebar) in the end of the clip-on bar. The stock grips are rubber so I just used an exacto knife around a socket large enough for the mirror to fit through. Your RSD grips probably have a metal end.
Got the Outerwears & Dobeck EJK installed over the weekend & did a little tuning to it. *It runs great & I am getting slightly better mileage out if it. *It seems to rev quicker & has much better throttle response but that may be the EJK. I like hearing that open throttle body when at full throttle. *
I saw the velociraptor but didn't think it really looked like a velocity stack, too short & wide. I did think it was cool they put a K&N filter in it but the size of the filter I think would choke down the air flow, probably less filter sq/in than a stock filter. Plus it doesn't function as a velocity stack since the mounting flange is in the flow of the stack so there is not a smooth flow from velocity stack to throttle body throat.
