Single tail light for brake/run only
Single tail light for brake/run only - Solved
Hi everyone,
On a 2011 sportster with the 2 tail lights that function as run/turn/brake, would it be possible to wire just one of these to work as run/brake only?.. I've been trying to do this myself but haven't been able to figure out the correct wiring.
If possible, how would you wire it?
I have the 3 wires, black/blue/purple.
Thanks!
Thanks!
Just curious, but why didn't you run the sparto as your run/brake and the strut lights as just blinkers?
Hi everyone,
Thanks!
Thanks!
The sparto light has just a red and black wire. Single filiment bulb. That's why it is a running light only. The LED's were set up as a blinker/brakes already so that's why I decided to just leave the Sparto as a running light only. It can be wired up as a running/brake light also though.
Yeah I tried this way, and it works but it will blink if I use that side turn signal.. I would like to make it only run/brake if possible.
Would you happen to know how?
