2012 Iron Battery Removal Tips?
Hey,
I am trying to remove my battery from my Iron and i'm finding it a real pain in the ***. The manual says to remove the -ve jumper from the chassis so i can slide the battery out. Where that nut is located I'm having issues accessing it with a "cheap" swivel socket.
Any tips or tools used? washer size; 7/16? Easier way to access?
Do you know what wire size is used so I can make a longer jumper and replace this short one?
First thing I did was pull the main fuse. I then took my time and, as per the manual, removed the negative side first. I removed it from the battery terminal. It was a slow process because there was very little slack, but I did it. I then removed the positive. To put it back I just reversed the procedure. There's not much room to work but I just took it slow.
Imold
05-12-2013 07:28 AM
