1970's FL hard bags on a 2012 XLC
Old 11-26-2012, 06:59 AM
Proteus's Avatar
Proteus
Proteus is offline
Default 1970's FL hard bags on a 2012 XLC
Hi Guys,
some pictures of the installation of 1970's FL hard bags on a 2012 XL 1200 C
Home made brackets, with a flat iron bar from the DIY store, I used the same raw material to relocate the signals. The interconnection between the two bags on the underside is made with a red copper tube. Bags are for now put in primer paint, I still have some scratches to fix. Test rode it for the last 200 miles, they rattle a little at idle, but no problem at 75 MPH on the highway, they're still hanging on the bike
I'd like to get them closer to the bike, but the only way to achieve this would be to cut away a little portion of the fibreglass around the chocks, the main problem being then the bags couldn't be opened fully as the seat is in the way. Moving them further after is another option, but this doesn't look good IMHO. Still looking to improve the brackets anyway once I've put another seat...
Comments welcome, even if some will tell me they don't fit on a Sportster...
Old 11-26-2012, 01:38 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
On the original big twins they were mounted behind the shocks, as are the smaller version on Sporties of that era. They get in really tight without the shocks in the way! You've done a neat job, well done.
Old 11-26-2012, 01:58 PM
Wakko47's Avatar
Wakko47
Wakko47 is offline
They definitely look better with the fat front tire, but I do agree they're too wide. Not sure how you'd be able to really fix that with the shocks in the way. How'd you bend the metal bars?
Old 11-27-2012, 03:01 AM
Proteus's Avatar
Proteus
Proteus is offline
the iron has been cold bent, I've put a section into a big vice and just hammered the other end into shape. No torching needed for this.
the Sportster's bags from the same era are smaller in size, but really hard to find at a decent price, certainly here in Europe. The other problem is that earlier Sportsters had their rear shocks put more forward, it would have been easier to put them tighter to the bike if the newer models were built the same way.
Anyway, this is a work in progress, they'll get tighter to the bike, once I cut out the bags to round the schocks and change that seat, thinking to go the police solo seat way.
Old 11-27-2012, 07:34 AM
DavidStiebel's Avatar
DavidStiebel
DavidStiebel is offline
Pro,
Not bad, the bags might want to be brought closer to the frame & leaned outward a touch, the front hinges could be removed & replaced with latches, hinge from the side with leather or similar like HD dose currently.
I like this look and want to do something similar as the HD sportster bags are tooo smaLLL! Also I want to paint them something cool/interesting.
Show us how it comes out, good job.
Old 11-27-2012, 08:16 AM
Proteus's Avatar
Proteus
Proteus is offline
Hi David,
I either thought about the side hinges and front & rear latches, but I'd like to let them "as is", even if I ditched the H-D system front separable hinge and put other more solid hinges.
Now thinking to put them closer to the bike, really close, and building a system that would allow the bags to swing out a little to fully open them...
Old 12-03-2012, 11:38 AM
ev0lution7's Avatar
ev0lution7
ev0lution7 is offline
i love these bags! good job!
Old 03-01-2013, 09:58 AM
mikek87's Avatar
mikek87
mikek87 is offline
I was thinking bout doin this but wasn't sure how it would look. They look simaler to street glide bags are they about the same size.
Old 03-01-2013, 10:24 AM
Proteus's Avatar
Proteus
Proteus is offline
I can be wrong, but I think nowadays SG bags are bigger than those.
Old 03-01-2013, 10:31 AM
grbrown's Avatar
grbrown
grbrown is offline
SG bags are similar in shape, but significantly bigger. I have an early Evo Glide and SG bags are even bigger than mine (I have a set of both). Harley made Sporty bags similar to those Proteus has, but smaller and neater. A feature of the early bags is that they are identical, left and right, while the later bags are handed, with indents so they fit closer round the shocks.
Quick Reply: 1970's FL hard bags on a 2012 XLC
