No, they are cleared over. If your really good it is possible to sand the clear off the decals, feather out the edge and re-clear. Most likely though you will end up breaking through the color and into the primer below.
Hey OP - There are some You Tube vid of dudes that have attempted doing so. I goofed around with this when stripping that purple king tank I recently installed. You can likely get the decal off, but removal will be obvious and your clear coat will be f&%$#d-up. Guess you could then attempt to sand the remaining clear, not remove any base color, and then re-coat the tank … but now I’m just rambling about chit I know nothing about.
Seen it done on a buddy's late '90s big twin, don't remember which model but a really good friend who has done a few cars for me did it. He sanded the clear off, removed the decals, feathered the clear, recleared the whole thing then did some letteing in gold leaf.
