Screamin' Eagle Heavy Breather
I've had my SE Heavy Breather for a couple years...I put the Bassani Street Sweepers on at the same time as the breather and got her tuned up. Performance increase was noticeable, and I dig the looks of them.
Pic taken soon after I installed pipes and breather...with rain sock.
Last summer...
Last summer...
Location: In the foothills of southwestern NC - US of A
The Heavy Breather is but one of many different types of Air Cleaners that will let your bike breath easier and afford your engine more air [more air ='s more fuel ='s more power!], but my thoughts on the cover would tend to make me believe that it would be restricting the airflow, creating a detritment to it's purpose of increased air flow.
I run a K&N Air Charger intake on my '09 Iron and like the looks of the "open" filter design, and despite my original fears of it "sticking out" or getting in the way of my leg during riding, it has proven to be no different than the stock ham can.
K&N Air Charger 63-1126 can be found for under $300 if you look...
There are of course less expensive alternatives and about a kazillion other types that are smaller so I suggest you take a looksee around [I took weeks to decide on the K&N, LOL] and you might find something that tickles yer fancy more than the Heavy Breather.
One thing worthy of mention about adding aftermarket exhaust and intake systems...you should know that Harley Davidson engines run lean, meaning that they are notoriously setup from the factory to burn "less" fuel, to satisfy the [E]nvironmental[P]rotection[A]gency requirements for pollutants emitted into the atmosphere from their motorcycles, and as a result of this "lean" condition the exhaust and engine temperatures run high, which although not causing damage in and of itself, it will however rob YOU of performance.
Now, if you decide to move away from stock and add ONLY a less restrictive exhaust system/pipes/mufflers, this isn't going to make your engine run leaner, and by the same notion, if you add JUST a less restictive air cleaner/intake system this alone will not add to your lean engine condition. BUT, if you add BOTH aftermarket exhaust AND a less restrictive air cleaner/intake, this combination will definately make your lean condition worse! Oh what to do.
So you may now ask, well, what's the use or purpose of exhaust [besides making your bike "sound" like a Harley] and an intake [the combination of both is known as a "Stage 1" modification] if they in combination make my engine run even leaner? Well, the combination of less restrictive exhaust and intake give your engine the POTENTIAL to run like it's supposed to, but only if you add one more thing...a tune. This can be accomplished in a number of ways...1] with the addition of the "Xied" series of add on gizmos which when placed inline with your stock 02 sensors, trick your ECM into providing more fuel to help lessen the "lean" factory condition, 2] purchase and install a "tuner" [Power Commander III/V, HD's own tuner, etc.] that you can use inline with your ECM or one that can "flash" [Power Vision, etc.] your ECM with an appropriate "MAP" that will eleviate this lean condition and provide adjustments to take advantage of more fuel during most ALL driving conditions, or 3] you can bring your bike to a dyno shop and have a tech run your machine through the paces and set up your ECM so your engine is running top notch [hopefully, LOL] for "X" amount of $$.
Regardless of your choice of intake you can hardly go wrong with the Screamin' Eagle stuff, but since there are literally hundreds of choices to choose from please take the time to investigate the many other options out there, which are more often less expensive and more "unique" to make your ride YOURS and stand out in it's special way.
Peace out, best wishes on your quest, and ride safe.
=8^)
aka DrewBone
aka Andy
=8^)
aka DrewBone
aka Andy
Last summer...
Last summer...
Here is the a/c I plan on buying here soon.
http://www.figuremachine.com/product...-c/xlflowc.php
11wideglidet&k
Exhaust System Topics
13
01-01-2015 10:04 AM
