How much oil should be behind the cam cover?
Old 02-25-2013, 12:54 PM
Ms54Coupe's Avatar
Ms54Coupe
Ms54Coupe is offline
Default How much oil should be behind the cam cover?
I bought my 94 883 in late summer last year...rode until it got cold and parked it. Anyway, I took off the cam cover and hardly any oil came out...the housing was pretty mich just glazed...but then when I took my oil tank off it was absolutely full. Does the oil syphon back up to the tank when these bikes sit?
Old 02-26-2013, 07:17 AM
Sportstatler's Avatar
Sportstatler
Sportstatler is offline
I took my '03 cover off to install new cams....hardly any oil, I think its normal...
Old 02-26-2013, 07:20 AM
Madnss's Avatar
Madnss
Madnss is offline
Received 1,051 Likes on 568 Posts
Oil will not pour out like you are thinking it will. Oil does not siphon back up, it takes a pump for that. Oil can drain into your crankcase sometimes after sitting for long periods.
Old 02-26-2013, 07:40 AM
Ms54Coupe's Avatar
Ms54Coupe
So does the oil pump push the oil back up to the tank and then it drains back down into the motor? I'm not familiar with the direction of oil travel and am just curious
Old 02-26-2013, 08:31 AM
1984_FXRT's Avatar
1984_FXRT
1984_FXRT is offline
yes - XL engines are "dry sump" engines, in which the oil is pumped both into and out of the engine. most cars use a "wet sump", in which the oil pan holds the oil under the engine, the oil pump pressures the oil INTO the engine, and gravity handles drainage back into the oil pump.
Not seeing puddles in your cam chest is a good thing.
Mikeduke108
06-28-2014 04:08 PM
fatboy1729
02-26-2014 07:33 AM
NYCFXDC13
06-01-2013 03:38 PM
Miket
Oil Archive (no new posts)
12-28-2010 05:36 PM
Dark_Celery
09-11-2010 01:29 PM
Quick Reply: How much oil should be behind the cam cover?
