HELP with progressive shock install
Old May 24, 2013 | 09:52 PM
Agiuliano10's Avatar
Agiuliano10
Default HELP with progressive shock install
just installed some progressive 412's. If anyone is running these and remembers the order of spacers/washers they used on a nightster please share. I went with what was stock had to adjust to get the shocks as straight up and down as possible.
Attached Thumbnails HELP with progressive shock install-image-1.jpg   HELP with progressive shock install-image-2.jpg   HELP with progressive shock install-photo-1.jpg
Old May 24, 2013 | 09:54 PM
Agiuliano10
on the top from outside going in i went: bolt, washer, cover, through shock, shoulder sleeve, spacer.
on the bottom from out going in i went: bolt, washer, shoulder sleeve, through shock, spacer.
Old May 24, 2013 | 11:39 PM
Scrambler900's Avatar
Scrambler900
I did the same on mine. I just made the shocks straight up and down. Been riding it that way and its totally fine. They really improve the ride. It makes you see how bad the front suspension is as soon as you go 100 feet. That's next on my list.
Old May 25, 2013 | 06:58 AM
cHarley's Avatar
cHarley
There is no single "proper" order for the spacers.
The idea is to make sure the shocks are straight (up an down), and spaced far enough out (especially on the right side), so that they aren't hitting or rubbing on any other parts, like the belt guard.
Old May 25, 2013 | 09:42 AM
Agiuliano10
ok, and did you just eyeball it to see if they were straight or did you use a level or something?
Old May 25, 2013 | 09:53 AM
cHarley's Avatar
cHarley
Unless you're cross-eyed, just eyeball it.
Old May 25, 2013 | 10:06 AM
ynots's Avatar
ynots
Some cyclops prefer to measure
Old May 25, 2013 | 03:48 PM
RATROD HOG's Avatar
RATROD HOG
well just get the mic out and check it.....................lol
Old May 25, 2013 | 11:40 PM
R Eggler's Avatar
R Eggler
I just went through the same thing today doing my 412's. I think I bolted and unbolted all 4 bolts 5-6 times each because it just never looked 'right' to me. I did the way you did, because that's how the poor directions say to do it, but still doesn't look right.
Old May 26, 2013 | 07:55 AM
Agiuliano10
at least im not the only one
