sportster extra plate clutch kit writeup
#71
It's just a cleaner grab. Off the line and hitting 2nd gear hard will does the front wheel up MUCH easier.
I imagine it would shave a tenth off your 1/4 mile time since a better clutch grab will propel you forward better.
Only reason I installed it was because I had to pull my primary anyway. Figured I'd do the clutch as preventative maintenance. Well worth the cost of parts.
slvrscoobie (04-21-2017)
#72
Received 2,189 Likes
#74
From what I can figure the spring plate is the same as 2 metal plates. Since my bike is near new my clutch is nowhere near worn. However I don't want to be the sucker whose plate goes extra early. So can't I just get two metal plates and replace the spring plate? That way I'll be able to go as far as the stock plates will take me but not have to worry about the spring plate going kaboom. Seems everyone in this thread was buying a whole new clutch disc set up. Am I missing something?
#75
Received 4,614 Likes
kuri77 (02-16-2018)
#77
#78
That's low miles, unless it's been a drag strip bike, the plates should be almost like new. Just put in the new extra plates and you should be fine for a long time. A lot of guys on this forum have said they got over 50,000 miles on the original plates and they were still doing fine. With a stock motor and just adding those plates, your original diaphragm spring would be fine, but your 1200 kit will probably be above stock hp, the clutch spring probably isn't a bad idea. Everything else should be good unless you're building a 100hp monster. When you get new fiber plates, soak them in motor oil (same as you use in the bike) for at least a few hours so they'll work right as soon as you fire it up. That's always in the instructions for new plate kits, don't know if anything will mention that just buying the extra plates.
#79
#80
Noise in the clutch at take off.
Noise , squealing since installed the new clutch.
I contacted energy one and they said it was the oil been squeezed out.
This has been going since i had it installed, took it back to the mechanic ,
took it all out and re installed and it still squeals.
Any ideas of what could be causing this
