Clutch Questions and Help
I noticed today when I went to move bike around the garage, that when I pull my cluth lever in, the bike still won't roll, as if it is in gear. If I put into to neutral it will move fine.
Next, I started the bike, pulled in the clutch lever, and now it rolls freely. But once I turn off the bike and disengage the clutch by pulling the lever, it still won't roll. I performed the clutch adjustment procedure several times and I still have the same issue. I took the bike for a test ride and I don't feel anything wrong. It just doesn't want to move when off and the clutch lever pulled in. 2013 Iron with 1700 miles. Thanks for any help and advise. |
Having this exact same problem and I took it in yesterday. It is the spring clutch plate going. Apparently it will keep getting worse. Harley makes them with a shitty part and the give out and it's common. The shop I went to says they replace one at least once a week.
Oh wow, that would really suck to have to bring it in. I will try calling them tomorrow. Bike is warrantied so hopefully it doesn't cost me anything.
The condition you describe doesn't sound unusual to me! Pushing the bike around in gear, with the clutch pulled in, is not going to be easy. If you can engage neutral easily while the engine is running, that seems fine. Leave your bike in neutral when parked, then you won't have to worry!
Bike will still have dome tranny "drag" if/when in gear and clutch engaged. You're fine, just park in garage in N and it's OK. Only park bike in gear when needed (i.e. on hill or uneven ground). This way you don't look like an idiot when trying to start bike in gear...;)
Originally Posted by grbrown
(Post 11947376)
Sounds normal, but like Daman said, the spring plate is an issue for Sportsters. The brass rivets on it tend to last around 25,000 miles, give or take depending on your luck/riding style. The good news is, it's covered by the warranty. You'll be fine for a while with your stock clutch unless anything goes horribly wrong, so I'd wait until at least after the break in is complete before making any changes to it. If you do end up replacing your clutch at some point, look into something that eliminates the spring plate.
But yeah, for now, you're fine. |
Assuming the clutch is adjusted properly and it is not trying to move forward when the engine is on, it is in gear and the clutch lever is pulled in...
The reason why there is drag when in gear and not running, is that the oil is cold and thick in the primary/tranny. This oil is "sticky" between the clutch plates, so even though the clutch lever is pulled in, and the clutch is mechanically disengaged. that oil is sitting between the plates making it hard to move. This issue can be made worse by having too much oil in the primary, which is a common occurrence. |
Originally Posted by USMC_ech110
(Post 11947104)
I noticed today when I went to move bike around the garage, that when I pull my cluth lever in, the bike still won't roll, as if it is in gear...
Originally Posted by DK Custom
(Post 11949734)
The reason why there is drag when in gear and not running, is that the oil is cold and thick in the primary/tranny. This oil is "sticky" between the clutch plates, so even though the clutch lever is pulled in, and the clutch is mechanically disengaged. that oil is sitting between the plates making it hard to move. This issue can be made worse by having too much oil in the primary, which is a common occurrence. Make sure you do the clutch adjustment procedure with the engine cold to minimize this type of issue. |
© 2024 MH Sub I, LLC dba Internet Brands
