What did you do to Your Sportster Today?
#5001
I just finished installing my Hammer 1250 jugs, pistons, carb jets and Dyna ignition. Today will be my first ride - I did the first heat cycles yesterday. Throttle cable fell apart when I was disassembling stuff. That replacement took me a long time. But I'm stoked now to take her out for a short run.
Had you previously swapped out the clutch ? just wondering...
thanks,
T.
#5002
Received 2,189 Likes
(prior 883->1200 primary gear/chain swap, Energy One/Muller power
clutch swap)
Adusted the primary chain, adjusted the clutch pull.
(Edit: forgot to mention that I replaced the bolts with AlloyBoltz,
and to the horror of some, using ATF type 'F' in the tranny)
A big shout out to Steve Cole at TTS for updating the Mastertune
Sportster Cals! I spent some time coping timing/AFR tables to the
new MT9 base so it'll be ready for some VTune3 recordings after
the inital fire-up/break-in cycles.
T.
clutch swap)
T.
#5005
#5006
Im learning here. T. doesn't know roll model status has been attained. I even went and bought some of those field manual holders from agri supply. Cant go all Charles Barkley.
#5008
installed my mirror extensions. Didnt work out as well as I hopes, as using the 'upside down' for the inverted mirrors ends up interfering with the clutch lever - unless you point it about 45* forward so the bolt/nut is in front of the clutch lever. throttle side worked out pretty well. Definitely moves is farther out though, even an inch is extremely noticeable.
#5009
#5010
Fedex arrived and I did this:
FuelMoto Delivered!
I started it after installing the custom map, and I dunno, but I think it Sounds better than the PC-V I have. Plus the data and being able to use the narrow band at least O2 make me feel better.
Now Im waiting for UPS, and my hammer impact AC
Also rerouted the wires from the handle bars so they slip behind the headlight again. I wish someone had said a year ago, the tank comes off with 2 bolts, and 3 plugs. Cause man its So easy. wiring my USB would have been so much easier. all anyone said was 'just take the tank off'. haha. Well yea, Just take the tank off, its Super Simple!
FuelMoto Delivered!
