Oil Pressure Gauge
Oil Pressure Gauge
I have an analog temp gauge in my oil tank cap. I've been looking for an analog oil pressure gauge. Anyone have any suggestions on a brand or style they like. I have a 2012 48. I like the ones that install in the side of the rocker with a simple 90 degree pipe fitting, but that seem to be for the irons not evos. The newer ones look like you have to run a braided hose.
Received 8,248 Likes
+1 - EVO Sporties work on oil flow not oil pressure. You'll spend most of your time looking at less than 10 lbs.
No oil cooler needed in Washington state. I'm a boiler operator and I like to keep an eye on pressures and temperatures. I would imagine that the pressure would change with the rpm of the engine. Volume doesn't create pressure but as the oil heats up in a closed system pressure will rise. Is the Harley evo just a splash system for oiling?
This topic has been beaten as bad as what oil to use. They call them idiot lights for a reason... Sensor bad, nut loosens, faulty wire, bulb out, etc. On the other hand, The oil pressure gauge never goes out unless you have no oil pressure. I don't care if it says 2 lbs you know you have oil pressure. My gauge is 8 to 12 lbs at idle and about 20 lbs running down the road... How many lbs does your idiot light say???
I bought my guage at HD dealer for about $60. It comes with everything needed to mount it to the engine, and that's where I like it out of the way. I only look at it now and then so it does not have to be off the top of the rocker boxes. Nice to know you have pressure when you first crank up. Also when temps get summer hot[90*] pressure will drop and then I go to straight 60wt oil and normal pressure resumes.
Why not try an automotive style electric oil gauge? Like a VDO or other brand. I used an electric oil temp and oil pressure gauges on my VW bus. The oil sender had a terminal for the gauge as well as the warning light.
Johh
