input on burley slammer rear shocks
They are not called 'slammers' for nothing! They have very little travel, so I doubt if your weights will matter much, you are likely to find life pretty uncomfortable. To avoid bottoming out you need to consider using significantly longer and better quality shocks.
Shocks are one of the most popular topics, across all models, on HDF. Many members chase nirvana by buying cheap short shocks for looks, but to be honest the suspension industry can only do so much, if travel is so short.
Re: same look without bottoming out - You can't fool with Mother Nature or the Laws of physics... you can't have it both ways. Either look 'Cool", or ride in comfort and safety, your choice.
"He Who Lives In Joy Does His Creator's Will".
The Baal shem Tov, Founder of Chasidic Judaism... ca. 1750's
I have those exact shocks on mine and I've ridden 2 up with them on there. I turned the pre-season all the way up and removed the solo seat bolt from the rear fender and it rode fine, didn't bottom out either. I'm 6-4 and about 190 and used my 140 pound sister as a guinea pig the first time I took it out with that setup. It's not the most comfortable ride mind you but like the guy above me said you can't really have both comfort and cool.
