Oil tank leak
Old 07-21-2014, 05:44 PM
Dustin Miller's Avatar
Dustin Miller
Dustin Miller is offline
Stage IV
Default Oil tank leak
I've got a '90 1200 and have been doing some oil trail detective work. All the hoses are in good shape yet there is a drip coming from the bottom of the tank. I've removed the tank but it's still difficult to tell. Does anyone know a way to check for leaks in the tank itself after removal?
Old 07-21-2014, 05:50 PM
cHarley's Avatar
cHarley
cHarley is offline
Clean and dry the tank, plug the hose connections on the tank, then fill it with liquid. I'd probably fill with something thinner than oil, like mineral spirits.
Old 07-21-2014, 08:06 PM
John Harper's Avatar
John Harper
John Harper is offline
Received 1,628 Likes on 1,124 Posts
These tanks are prone to cracking along one of the battery mounts. Brilliant job of engineering hanging a 13 pound battery from two small bolts. Might be able to braze the crack. Go over to xlforum.net for some other solutions to this problem. Mine has not cracked on my 1991, but I'm looking to switch to a LiFePO4 battery when mine finally dies.
John
Old 07-21-2014, 08:11 PM
Dustin Miller
Stage IV
Thanks very much, it looks like it might be the mount just about the drain pipe that is causing the problem. I'll check the other forum as well.
Old 07-21-2014, 10:09 PM
John Harper
I think that's where it cracks.
John
tpitman
04-22-2018 10:07 AM
izzyfutch
Oil Archive (no new posts)
03-04-2013 01:31 PM
Billytoppless
10-07-2008 10:22 PM
Toe Cutter
Ironhead
11-17-2007 01:22 AM
bobbsterkid7
07-17-2007 08:07 PM
Quick Reply: Oil tank leak
