Flanders Black Drag Bars (drilled) w/ ISO grips and Powdercoated 1200C Riser
Flanders gloss black 25 degree drilled drag bars with iso grips installed. They were put on the bike and bike was traded in before I could ever ride it. The only markings on them are from the mounting parts. (center clamp, switch housings).
1200C riser powder coated black in great condition. Same story, installed but never ridden. Also has the harness that plus into any 14 and up can bus Sportster and fits the 1200 housing if you are coming from a non-1200c setup (may work on other years, buyers responsibility to check).
WARNING: I had this setup on a Iron 883, but it will not fit with a 3.3 gallon tank. I intended this setup for use with a 4.5 gallon tank (was on order when bike was traded), however it should also would with the 2.1 gallon tank.
Bars and grips - $180 shipped
1200C gloss black powder coated and harness - $200 shipped
If you buy both I will go $350 shipped or best offer!
Any questions or more pics, just ask.
