Mark this thread as Unsold
SE Race Ignition Tuner 32124-04B / ICM
Selling my Race Ignition Tuner and stock ICM it's married to. Good cheap way to get a little extra power by adjusting the timing curve with a custom map or one included on the cd. Will work on 04-06 Sportster 883/1200 or a build. Also allows you to bump the rev limiter up to 7000. There's a map for a stock 1200 and one for a stock 1200 with cams on the cd. Same with the 883. You can tweak those to make one that works best on your motor.
This is a race tuner, not a street tuner. Meaning your motor won't pass emissions. A good tuner that actually does something besides bumping the rev limiter up. Fix the screwed up ignition timing your bike came with stock.
If you can't swing an aftermarket Ignition, this is a good cheap alternative that does the same thing with the stock ICM.
Even if you just run it for a year or 2 til you can swing a TC88A, it's worth the $70 shipped to the lower 48 to have a better running motor with a little more get up and go. Got rid of my occasional carb fart too.
I even have a good map for a high compression build if you want it.
$70 shipped to lower 48 for the tuner and stock ICM off an 05 1200C with 28,000 on it.
