Rear Wheel Bearings - Page 2 - Harley Davidson Forums
Go Back  Harley Davidson Forums > This 'n' That > The Dark Side
Reload this Page >
Rear Wheel Bearings
The Dark Side For those members running "Car Tires" on their scoots. This is for their discussion only and not a place for "non dark siders" to mouth off about their negative opinions of this idea!
Rear Wheel Bearings
Old 03-24-2018, 11:29 PM
rlh7677's Avatar
rlh7677
rlh7677 is offline
One Of The Regulars
Only Harley ABS bearings will work with your system to my knowledge but they are not failing as frequent as the non ABS bearings. So you need one ABS left front and can use a Timken on the right, the rear is the opposite and don't forget pulley bearing , non ABS. And pay attention to how the ABS bearings are to be installed, if reversed they won't work. Hope that helps.
Old 03-25-2018, 06:51 AM
EasternSP's Avatar
EasternSP
EasternSP is offline
The ABS bearing on the front wheel is the one that's leaking grease. I've replaced the front wheel bearings once already.
Old 03-25-2018, 09:30 AM
justbike1
justbike1 is offline
New Member
You can get an ABS All ***** bearing, other than that from what I have read there aren't a lot of other manufacturers for that one.
Old 03-25-2018, 09:53 AM
Tired's Avatar
Tired
Tired is offline
Performance Machine offers an ABS encoder kit that allows you to use any bearing that fits the hub as an ABS bearing. Just another option.
The Following User Says Thank You to Tired For This Useful Post:
Drifter-10 (03-28-2018)
Old 04-02-2018, 09:41 AM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Originally Posted by justbike1 View Post
Harley wheel bearings are absolute garbage, Ive had one fail in the front in 3000 miles, huge safety issue I dont know how they get away with selling such garbage that can put lives at risk, Always run darkside never had a rear bearing go, however replacing mine with all ***** at the next tire change, 30000 miles as preventive measure.
It is not so much that the bearings are garbage...but they are the wrong bearing for the application.
Ball bearings really can't take any side loading...like when you are going around a curve...for that you need a tapered roller bearing...like Harley used from 99 down. A TRB properly maintained would outlast the bike.
Old 04-02-2018, 10:21 AM
justbike1
New Member
My buddy has a goldwing, front bearings look exactly like harley from outside, 100,000 miles never been touched
OPDSam30
05-04-2018 12:56 PM
cike
10-15-2017 06:01 PM
junkyardscrounger
09-12-2017 10:30 PM
olemans85
Wheels/Tires
24
07-16-2016 01:18 PM
Jaftica
Touring Parts
06-16-2016 11:23 PM
Quick Reply: Rear Wheel Bearings
Featured Sponsors
Vendor Directory
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
