The Dark Side For those members running "Car Tires" on their scoots. This is for their discussion only and not a place for "non dark siders" to mouth off about their negative opinions of this idea!
195/60-16 will it fit
Old 06-05-2019, 11:49 AM
smitty901's Avatar
smitty901
smitty901 is online now
Received 9,584 Likes on 5,162 Posts
6,000 miles on the 195/60R16 car tire on the bike rear with the sidecar. Tire still looks like new. If it had had any motorcycle tire on it it would have been replaced by now due ti center wear.
Old 06-16-2019, 11:50 AM
terryrh's Avatar
terryrh
terryrh is offline
Has anyone heard of anyone using or used themselves the Federal Formoza AZ01 All- Season Radial Tire-195/60R16 89H?
Old 06-17-2019, 04:13 AM
smitty901's Avatar
smitty901
The brand and model tire is not a big deal . What you want to avoid is so called rim protector tires. They have a side wall designed to hit the curb before rims do and that makes them a bit wider. Also you want to avoid . Also you should avoid asymmetric tire the tread design id different left and right of the center line.
terryrh (06-19-2019)
Old 06-19-2019, 12:09 AM
terryrh's Avatar
terryrh
terryrh is offline
The AVID is tried and proven and <$100 - It works for me. No need to go trying craziness just to end up where I should have started to begin with.
Old 07-18-2019, 06:01 PM
bigpappa160's Avatar
bigpappa160
bigpappa160 is offline
Default Ds tire
Originally Posted by Bonnie Storm
I can't see any reason why it wouldn't fit (195/60r16) I think one of the reasons some go with the 195/55r16 is there is a wider selection of tires one can use even if they are a little shorter. The 195/60r16 really has a scant few to select from.
On my 2010 Street Glide, I'm running a 205/60r16 on the rear and a 150/70-18 rear tire on the front in reverse. (double dark)
Hey Bonnie Storm, I have a 2012 Street glide and wanting to go to the DS. On the 205/60r16 rear ct does the tire change the speed on the speedo or does it read the same like when the mt was on your bike? Also the 150/70-18 that is a motorcycle tire right?
leadman
10-03-2010 02:33 PM
RandyDowdy
04-27-2010 11:24 PM
deadreckoning
Shovelhead
06-12-2009 06:27 AM
Highwayman97
04-30-2008 09:36 PM
Native American
09-03-2007 10:24 PM
Quick Reply: 195/60-16 will it fit
