Darkside a 750 Street with sidecar.
So the RGU sidecar rig has gone dark. Now time to figure out the Street 750 sidecar rig . factory tire is a bit odd shaped a 140/75R15.
looking at 3 options now that should work. Looks like plenty of room . With a Street tugging a sidecar IMO a tire that lower ration would be better than one that raises it. However 1/2 MPH at 65 would make no real difference.
165/65r15 would be an inch wider than stock and it you be very close on gearing 65.49 vs 65 MPH
165/60R15 would be almost prefect 63.68 vs 65 Mph.
155/60R/15 would work 62.36 vs 65 mph
Big issue. It seems that once you get down to a 15 inch motorcycle rim things change. A 15 inch Car tire will not fit right on a 15 inch motorcycle rim different size. To expand my efforts .Is there a 16 inch rim that will direct fit a 2015 Street 750? I Know the 2018 Street Rod has a 17 inch rear wheel. No giving up on this yet.
Never give up until you are sure it won't work. keep in mind I am doing this at home with some old spoons. Broke the tire down again. lubed it some more at filled it with air at110 pound pop the breads popped into place all around. Let air out to 35 pound no leaks.
I did this on a use rim so did not care about scratches it was from a wreck.
Next step pick the size I want to use buy a new tire and mount it on the bike. This is going on a Street 750 sidecar rig.
I kept finding a lot of reasons why it would not work, Some claiming a motorcycle 15 inch was a different size. I talked with Hd dealer today he said that bead on the wheel they have can be a bit of a pain for the tire to pop over . Now time to pick a size to try Looks like a 165/65r15 will work.
perki48 (05-15-2019)
As I said a 15" CT on a motorcycle rim is extremely tight. but if you do it the other way around a 15" MC tire on a car rim is too loose to hold a bead if you lose air. And before someone comments about "why" would you do that I had (and still have it) a VW rim that has been dimpled for spokes. Ran it on a shovel also but found out when I mounted a MC tire on it that it was too loose.
perki48 (05-16-2019)
Research is done. Decided on a 155/60r15 for the Street.. it is very close in width and just slightly lower. .
20 mph (32.19 km/h)19.19 mph (30.88 km/h)
25 mph (40.23 km/h)23.98 mph (38.6 km/h)
30 mph (48.28 km/h)28.78 mph (46.32 km/h)
35 mph (56.33 km/h)33.58 mph (54.04 km/h)
40 mph (64.37 km/h)38.38 mph (61.76 km/h)
45 mph (72.42 km/h)43.17 mph (69.48 km/h)
50 mph (80.47 km/h)47.97 mph (77.2 km/h)
55 mph (88.51 km/h)52.77 mph (84.92 km/h)
60 mph (96.56 km/h)57.56 mph (92.64 km/h)
65 mph (104.61 km/h)62.36 mph (100.36 km/h)
