Gone to the Dark Side - Ongoing Review
#91
I'm running 205.55.16 Michelin , no problem fitting it on to the bike .but can't go bigger
½" clearance between the edge of the tire and fender .
Speedo is out about 2 maybe 3 mph. Comparing GPS to speedo a 195.60.16 would be fine as it is slightly taller (½") but you have a very limited selection
Done about 4000 miles and will buy another.
Heading on a 14000 mile trip to Alaska tomorrow .
There is a website google Darkside tires. Or darkside forum
#93
#94
Time (or past time) for this years update.
I now have about 37,000 miles on the bike, with about 25,000 of those on the darkside and about 10,000 double dark.
Overall I am still extremely pleased with my setup. Nobody and I mean nobody can generate the kind of braking Gs I can. My double dark setup my braking ability is stupid good. It has literally saved my butt when a pickup pulled out in front of me. With my huge contact patch the ABS has little to do.
As most of you know running a car tire results in superior wet pavement performance. I think double dark ups the ante even more... Nice to feel confident when the weather turns to crud, the skies open up and you still have hundreds of miles to go.
The bike rides smooth as silk with Ride On in both tires. Still (thank G-d) have not got to try out its leak stopping properties.
If I were to buy a new bike I do not think I would wait to wear out the stock rear tire before putting on a CT. I would do it immediately and sell the stock tire.
#95
I have been riding Darkside on electra glides for a few years, I have bought a new bike in the past rode it home and swapped to ct immediately. I bought a new bike last year, thought Id wear out the bike tire then put on CT, couldn't do it, after about 6000 miles couldn't stand it anymore pulled it off garbaged it where it belonged and got my CT back on.
#96
#98
Edit: Ok i did not realize some HD models do just that, Example of which being the breakout. Bias front with Radial rear.
Save
#99
I know on a 4 wheel it does but on a bike it don't matter. I thought the same when I started and posted on a forum someone told me it don't matter on a bike, after trying it I found that was the case. Always run bias mc on the front and radial run flat on the rear. I will never go non run flat on rear. Just a couple weeks ago my sisters friend and husband were on their way home from vacation on their Harley, blew a back tire, he's dead and shes in a hospital 1200 miles from home all busted up.
#100
My question is what is the current best 195/60 tire to install with this, and where do you guys get these installed? I do not have tire tools and such, I do have a lift and can get the wheel off no issue. Its taking it down and getting it installed that I seem to have issues with, No one wants to touch it, as I get the "its to dangerous to run it like that, we don't mount them because of this" routine. I'm getting close on my rear and want to go this route but...
Thanx, Tim
Thanx, Tim
