The Dark Side For those members running "Car Tires" on their scoots. This is for their discussion only and not a place for "non dark siders" to mouth off about their negative opinions of this idea!
Gone to the Dark Side - Ongoing Review
Old 04-16-2017, 04:39 PM
perki48's Avatar
perki48
perki48 is online now
Received 4,099 Likes on 1,913 Posts
Originally Posted by razors edge
Thank you.
That's the info I was trying to get out of the local parts department.
I will see if I can get a part's page print out for compatability.
Just don't trust the dealers. If it is not listed as a replacement part they will not tell you it will fit. Be aware that "ALL" dyna frames from 06' until now with the exception of rake are the same so parts pretty well interchange.
  #82
Old 04-27-2017, 09:43 PM
razors edge's Avatar
razors edge
razors edge is offline
Default 16 inch fat Bob wheel
Alright, here we go. I will post pictures as this progress. Hopefully a 195 60 16 tire will be on my 09 fxdc super glide soon.
The following 2 users liked this post by razors edge:
Eggman1 (10-31-2018), perki48 (04-27-2017)
  #83
Old 05-18-2017, 09:16 PM
razors edge
Default 16 inch rim dyna
OK folks in a nut shell the installation of the 16 inch wheel was a little bit of a challenge. Wound up the spacer from the FXDF on the brake side and the spacer from the fxdc on the pulley side. So be prepared to keep an open mind on your spacers if you chose to travel down this road. The 195 tire was just a shade too wide and a 185 55R16 was a better fit. I went with a Dunlop sport 7000 that was 6 months old at the time of the purchase according to the DOT code. The mileage should be increased handsomely.
rkoivisto (05-19-2017)
  #84
Old 05-19-2017, 05:44 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,808 Likes on 3,313 Posts
Pics?
  #85
Old 05-19-2017, 07:58 AM
razors edge
Sure Why not. Just started riding this tire. So far so good. Running 28 psi for now. Corners nicely. Seams a bit more round than my previous c/t.
  #86
Old 05-19-2017, 08:20 AM
rkoivisto's Avatar
rkoivisto
rkoivisto is offline
Default Fat Bob wheel
I like the idea of a mag instead of spokes, but that mag would really screw up the looks of my Wide Glide.
On the other hand, the rear tire has less than 7k on it and it's not looking too good.
As a second bike, I don't expect to put more than 10K miles a year on it so if I may be able to live with the crappy tire mileage. If I only have to change the rear tire out once a year, I will make due with it.
Is your belt riding good and the wheel centered right? It sounds a little hokey to mix and match the spacers, but if it works....it's an option that I'll keep in mind. Maybe I can find a 16" wheel that would fit the Wide Glide a little better.
  #87
Old 05-19-2017, 09:48 AM
perki48's Avatar
perki48
I don't understand the need to mix spacers, I thought the swingarm was the same on all of the Dynas. Maybe I was mistaken.
  #88
Old 05-19-2017, 11:14 AM
razors edge
when I tighten the axel nut it would lock up the wheel via wheel bearings. The wheel is definitely running in the center of the swing arm.
  #89
Old 05-19-2017, 11:17 AM
razors edge
I like a mag over spokes due to spending time on the side of the road. With a mag I plug the tire and go. With spokes not so easy when you get a flat on the road.
  #90
Old 06-26-2017, 02:18 PM
Baloofalo's Avatar
Baloofalo
Baloofalo is offline
Getting ready to make the switch, however struggling on how to determine tire size.
2016 FLHTK. If i were to go with the Michelin Commander, my rear tire would be 180/65HB-16.
What Automotive tire size/brand/type should I be looking at?
Quick Reply: Gone to the Dark Side - Ongoing Review
