HARLEY: VCI map locked by dyno tuner
Hi all
Recently had my Bike dyno tuned and when i tried to access my map saved in VCI to lower my rev limit it crashed the Program after some discussions with tuner he finally revealed he has locked my map to prevent sharing which was and is not my intent
is there anyway to unlock ??
here is error msg
Application Domain: Screamin Eagle Super Tuner.exe
Assembly Codebase: file:///C:/Program Files/Super Tuner/Delphi/Applications/Screamin Eagle Super Tuner.exe
Assembly Full Name: Screamin Eagle Super Tuner, Version=9.0.0.0, Culture=neutral, PublicKeyToken=null
Assembly Version: 9.0.0.0
Assembly Build Date: 18/08/2015 12:06:48 PM
Exception Source: EfiTuner.Models.Concrete
Exception Type: System.NullReferenceException
Exception Message: Object reference not set to an instance of an object.
Exception Target Site: get_TableList
Stack Trace
at SPX.HarleyDavidson.Nolan.Models.Concrete.DelphiTun ingFile.get_TableList()
at SPX.HarleyDavidson.Nolan.DirectInjectionEngine.CTu ningPresenter.a()
at SPX.HarleyDavidson.Nolan.DirectInjectionEngine.CTu ningPresenter.d(Object A_0, CFileEventArgs A_1)
at System.EventHandler`1.Invoke(Object sender, TEventArgs e)
at SPX.HarleyDavidson.Nolan.Models.Concrete.CTuningMo del.d(String A_0)
at SPX.HarleyDavidson.Nolan.Models.Concrete.CTuningMo del.f(String A_0)
at SPX.HarleyDavidson.Nolan.Models.Concrete.CTuningMo del.LoadFile(String filename)
at SPX.HarleyDavidson.Nolan.DirectInjectionEngine.CTu ningPresenter.e(Object A_0, CFileEventArgs A_1)
at SPX.HarleyDavidson.Nolan.Models.Concrete.CTuningMo del.a(Object A_0, EventArgs A_1)
at System.Windows.Forms.Control.InvokeMarshaledCallba ckDo(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallba ckHelper(Object obj)
at System.Threading.ExecutionContext.RunInternal(Exec utionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
at System.Windows.Forms.Control.InvokeMarshaledCallba ck(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallba cks()
here is error msg
Stack Trace
He said he did it deliberately because the map is his intellectual property
He will lower my rev limit free but I need to take bike their ..140km round trip plus day off work for a 3 minutes job
The file is in vcI however it's missing the *.dt0 file extension ..adding the extension to file did nothing still can not open
He must have encrypted it or unplug vcI after flash and prior to file saving to vci
Correct ecm is not locked ..the map is locked in the vci
Honestly I'm happy with tune but had I know he was going to lock map I would've looked a tuner who doesn't lock maps
It was dishonest not to advise me prior ..nowhere is it stated that the map would be locked. If he feels that the map is his property that's fine just say so and give customers the choice
