The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
THUNDERMAX: Pathetic Fuel Economy - T-Max Experts HELP!
  #61
Old 08-17-2017, 08:56 AM
Max Headflow's Avatar
Max Headflow
Max Headflow is online now
Received 5,223 Likes on 3,607 Posts
Sounds good.
  #62
Old 08-17-2017, 10:33 PM
HoggyMtnBreakdown's Avatar
HoggyMtnBreakdown
HoggyMtnBreakdown is offline
I have just two more questions for you, Max, then I'll leave you alone (if that doesn't lead to more questions - LOL):
1. Why did you advance the timing so much on your 103 in the the lower RPMs (under 2000)?
2. Why did you retard it more in the higher RPMs (over 3500)?
  #63
Old 08-18-2017, 11:38 AM
Max Headflow
Not sure what you are asking. Is this simply in reference to other maps?
Advancing the timing at partial throttle at lower RPMs helps a little with throttle response and exhaust popping. It also helps burn all the fuel that is available which helps with closed loop AFRs. One thing to remember is that cylinder pressure is low at partial throttle.. Low cylinder pressure takes longer for the fuel to burn.
In the upper RPM ranges partial throttle is pretty much the same as lower rpm but at wide open throttle it has to be less. The cylinder pressures are much higher. Fuel burns faster.. I've used a dyno on occasion and simply tune WOT timing to where it makes the most power.
  #64
Old 08-22-2017, 10:31 AM
HoggyMtnBreakdown
Doesn't matter. You answered my questions and gave me the info I was after. Thanks. Appreciate all the help, Max!
  #65
Old 08-27-2017, 09:10 AM
Max Headflow
Switch setting in smartlink 4 which is for the gen 2 system..
Gordon61
The Dyno Room
11
05-03-2017 12:11 PM
dlporter
03-29-2016 11:40 PM
msr082881
02-20-2015 04:28 PM
Wildrat
06-13-2009 11:31 PM
ezlife
10-09-2007 10:12 PM
Quick Reply: THUNDERMAX: Pathetic Fuel Economy - T-Max Experts HELP!
