DYNOJET: Dynojet Power Commander III Using Too Much Fuel
I recently purchased my first bike, an 06 FLSTN with 6954 miles on the odometer, from a local H-D dealer and the bike apparenty had a Dynojet PC III previously installed. I've been riding the bike for several weeks now and am finding my bike to be using way too much fuel. The fuel light comes on with about 85 miles since the fuel tank was filled. I've tried "resetting" the PC III by holding all three buttons down, turning to the Ignition, then flipping the Run button without starting the bike. This doesn't seem to do anything and I can't seem to figure out how to manually adjust the fuel setting downward.
I've tried searching online and again am having very little luck. If you an help, please post up as I know I should be getting about 50mpg and right now I'm getting maybe half that amount. Thanks!
I typically fill it up when the low fuel light comes on which generally happens around 1/4 tank till empty. My latest fill-up was about 3.3 gallons at 85 miles.
I've downloaded a number of maps but didn't receive the cabling to connect my laptop to the module so I haven't tried mapping it yet. I'm not even sure which cable I need for this?
I have the same commander. the cable is a USB and instead of a micro USB head it is the larger style. You might have one in your house or be able to find one easily. You need to download the program to a windows machine and download a map that matches your mods. I have true-dual Vance and Hines pipes with an Arlen Ness intake. I am running a map for a V&H longshots with Screaming eagle intake and I lowered the numbers by 10 on the computer and loaded it on to the USBIII.
Important information----the engine has to be running to alter the fuel mix manually. The computer will only activate for 5 seconds to prime the system and then turn off untill you start the bike. this also includes loading of maps, the only way to avoid that is to buy their power cable.
Here are a couple of links to help.
This one is for a page with tutorials and the downloads. http://www.powercommander.com/powerc...dType=PCIIIUSB
Here is the power adapter so you do not have to have it running.
https://cart.dynojet.com/p-832-pciii...ng-module.aspx
Here is the cord for programming it. from PC to USBIII
https://cart.dynojet.com/p-823-repla...i-b-cable.aspx
Hope this helps and have a fun time riding.
The PCIII that was on my '06 Deluxe when I bought was a bit finicky about the order and timing of pressing the buttons to get into adjustment mode. I did not have the cable either. I bought the 9v battery connector so the setting could be changed without turning the ignition on.
I went with a PowerVision late last year and I've been happy once I got 'er tuned in.
Even so, 50mpg might be a bit optimistic. I've only achieved that one time and it was heading north on Hwy 395 with a tailwind. On average, I get 42-45mpg. I am not heavy on the throttle.
