HARLEY: Pro Super Tuner - Throttle position less than 100% at WOT
My logs are showing throttle position of 86.4% or 85.9% at the highest for throttle position when doing full throttle pulls. The highest value I've seen for the TPS is 3.81.
Is this common to see? I have about 15 pulls at WOT and they are all just like this.
This became SOP before each tune on cable driven. Amazing how many aren't hitting 100%. 85% does seem low. Collapse the idle completely. While logging data with bike off. Open throttle all the way and adjust throttle until you get 100%. Then then readjust idle cable to proper slack.
If this doesn't work. I have seen other problems of interference with aftermarket AC's. I have also seen on some aftermarket throttle bodies where the "wheel" the cables hook into contact the cable bracket. Which stops it from opening all the way.
I would address it. Not only for the best power. Because if your log is showing 100kpa, well. BUT more for how PE mode works.
Edited to add: Before getting the horse behind the cart. Have you visually checked the throttle blade?
Br125 (05-04-2017)
Derf_
06-17-2016 03:22 PM
christian0632
03-21-2008 01:38 PM
