DYNOJET: Who has just used the Quick Tune option on their powervision tuner
Slight thread revision, but looks like the best thread for the help I need.
I have done a quick tune adjustment to the current tune on my power vision. How do I save a copy of the tune (with the quick tune adjustments) so that I can then run auto tune on the map that has the quick tune adjustments?
Thanks
Thanks
It might be a good idea to check your tune after your flash it using the Load Copy, Current tune and saving it to a slot.
I have run into an issue with my 2013 Sportster where the PV will not write an updated "Adaptive Control min temperature hysteresis" temperature to the ECU successfully. I get a successful completion but the actual tune flashed does not match. It does successfully change the "Adaptive Control min temperature" setting.
I have also noticed a slight change in ignition timing when flashing some tunes.
Thanks
Thanks
The use that Tune (in the slot you selected) to enable Auto Tune.
See this link for visual instructions. page 13
http://www.powercommander.com/downlo...8100014.08.pdf
ubreal
10-27-2007 10:27 AM
