Other Devices: FP3 Won't stay connected to Bluetooth?
Just started today, it had been fine when ever I checked Sensor activity the past month, but today I wanted to try a different map and the damn thing either cuts out with trying to view/edit map screen or when I try to Flash the Map...
Sent a couple of Feedback Files to V&H...
I was seeing this behavior a little while ago. Had phone connected to both the FP3, and a Bluetooth audio receiver I plug into my iPod dock. This worked fine for a while, but recently started disconnecting from the FP3. I unhooked the BT receiver and the problem seems to be gone.
I have a suspicion that it might be related to an OS update on my phone - but not positive of that.
So if your phone is connected to anything besides the FP3 via Bluetooth, try eliminating those other connections.
Originally Posted by onecoolpilot
I had the same issue. This post says they had an issue and are working on an update to fix it.
Im at Android 5.0.1 and recently started have dropping of fp3 when tried to update an af setting and flash. Took a couple tries to work. Kept getting message about searching for device. I did not have any other bluetooth devices nearby. Obviously some type of update to some product other than fp3 is causing. May not even be ios related but another app
Gets to about 40% and the says unfortunately the app has stopped running
Both Amazon and Netflix apps have updated on my phone in last few days. They both have permissions to bluetooth settings. If have either, could try removing. Just shots in the dark
