The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
HARLEY: Can't Decide On MAPS To Use
Old 06-19-2017, 08:49 AM
evhid1's Avatar
evhid1
evhid1 is offline
Default Can't Decide On MAPS To Use
I am installing the Andrews 57H cams and +4 degree cam drive sprocket in my 2012 FLHTK. Which is best to flash the ECM with, a MAP that has slightly differnet exhaust and same cams or the SERPT SE204 MAP witch is about the same as the opening and closings of the 57H intake and exhaust events but lower lift and slightly different exhaust. I ask because I am wondering which effects the tune most, the spark advance differences in the maps or the open/closing events that are basically the same. Thanks in advance for any and all help.
Old 06-19-2017, 02:33 PM
Br125's Avatar
Br125
Br125 is offline
The 204 map should be a good place to start as the cam has almost identical specs to the 57h advanced 4*. Are you saying that you have a map for the 57h as well? I found that the spark advance tables were too aggressive on the SE 204 map and had to pull timing in a few areas before my bike ran smooth when I still had 204's.
Old 06-19-2017, 05:57 PM
evhid1's Avatar
evhid1
evhid1 is offline
Yes I do have a map for the 57h's and and the SE204 map does have more timing then the 57h map. So if you had to pull timing it might be best if I went with the 57h map I have.
SnoRider
08-22-2016 10:55 AM
Weeboy1
06-10-2015 02:49 PM
Buiceman
05-08-2015 11:14 PM
Jeckel
04-16-2015 09:35 AM
msr082881
02-20-2015 04:28 PM
Quick Reply: HARLEY: Can't Decide On MAPS To Use
