The Dyno RoomA special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
Sure, just by selecting the appropriate HD mapping in the list which is has your upgrades/ mods. And if you want to be sure to keep your warranty you better let the HD shop do it for you. You will pay extra but you will keep your warranty.
And to require the dealer to install pre-made maps to keep the warranty seems ridiculous!
From what I understand about this tuner you cannot adjust afr out of epa specs
, thats why I want to be sure it will work with pipes other than hd's.
Indeed, the only thing that needs to be changed/adjusted are the VE-tables. And for that you can use the auto tune function. As I said in the mapping list you will find a mapping with some free flow parts from SE, Like free flow AC and race slip ons. That will be a good map to start with, and take it from there. In the screamin Eagle catalog it states that this tuner will retain yr warranty.
No requirement to let the dealer do the work...only that the work is done correctly......
