DYNOJET: Still having spark knock issues!!! KILLING ME!!!
OK.... I'll try to make this short....
New plugs.... just because....no oil or buildup but slightly on the white side near a tan color...
Canned map from FM for my PV and Target Tune for 120ST with Boss Boarzilla
running lean and getting spark knock on FRONT CYLINDER.. 3 times as many vs the rear.. and sometimes not at all on the rear.
This is all happening above 2800 rpms and 45Kpa and up pulling hills at above 75mph is the main scenario I see this.. not flat land cruising.
So... I increase fuel by 5% from 2800 and up across the table... smoothed it out.
Almost at .895 lambda in areas even lower in the higher ranges ( still getting 38mpg )
a little better, but not alot... spark retard is set to 6 degrees.... never touched it
I pull out 6 degrees of timing ( and smoothed)from the FRONT CYLINDER in the the same range as the fuel table mod... still have spark knock on the front, and now the REAR CYLINDER has spark knock is almost keeping up with the front!!!!
WTF!?!?!?!
WTF!?!?!?!
I'm having pretty bad knock issues with my 110 build.... 0ver 100f/50r on a recent 250 mile trip. My bike is at ~11.3:1 static comp, 225 CCP.... going to change cams to bring that down.
Anyway, my tuner says they're false knock events from running SE plugs & wires. I changed back to the standard HD plugs, gapped at .035 and about 30% of the events went away. Maybe something to try if you're running the SE stuff.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Are you sure the knock events are real? Do you hear the "click" just before the timing starts getting pulled?
Also note that you want to pull timing in the cells just BEFORE the knock event, as it's a reactionary system.
Good luck.
Good luck.
Good luck.
Good luck.
WTF!?!?!?!
WTF!?!?!?!
Neverless -
Do you hear any ping/knock or are you just seeing knock events on your PV? Isn't the spark table advance just used to light the fuel at certain times for maximum efficiency and power and the the ION system just used to interrupt this lighting at times to keep the motor in a safe range? So you see the knock events recorded when "pulling up hills but do not see them when you are cruising on flat ground". Is this just the ION system backing advance off due to the load? Isn't this what it is supposed to do? I'm guessing that the advance shown in your spark tables are the best figures for efficiency and power but at times, due to load the ECM abandons them and pulls timing to prevent damage to the motor. Isn't this normal?
you can run your auto tune in a spark learn only setting. it will not make changes to your ve tables, just spark,,,,,run the auto tune session and check the log info and try to ride and see how it feels, just remember to save your current tune before flashing the spark learned auto tune session so you can go back if there is something fishy,
m
m
m
m
