DYNOJET: Power vision auto tune basic
Sorry if this has been addressed already but cant seem to find an answer. I have just installed a power vision from fuel moto. Got the fuel moto map downloaded on to bike. Question is regarding the tables of AFR.
I see that the tables for AFR are set to 14.6 for most cells. Question is when I start auto tune basic do I leave this alone? If I change the values any lower will it try to tune it to that AFR or will it automaticly tune at 14.6 because of the stock o2 sensors? Just trying to get the most out of auto tune basic before moving on to auto tune pro. I looked at the VE tables but that might as well be in a different language cause I have no clue what im looking at. Just need to know what to set my tables at to get a good tune for the moment. Main goal is cool running bike with power at the throttle.
Bike is a 2009 roadking with slip ons and stage 1 cleaner. Basic bike. Thanks for any help.
When you successfully get the ECM into Auto Tune mode it will alter the tables that need to be changed for tuning.then, after you collect the appropriate data, develops the new calibration, reinstall the calibration with auto tune disabled.
There is plenty of printed explanations and instructions for PV auto tuning. Study up and you
will have a much better chance of successfully street tuning your bike.
As you will soon find, there is a hell of a lot more to it besides modifying the default AFR table as it's fine as is.
Bob
Bob
Ok, so I will just leave all the tables as fuel moto sent it and just do basic tune. Then reflash all the changes and reset the fuel trims with every flash. Just trying to understand this thing. So what gauge does this thing tune too? Does it just take it to the capacity of the stock o2 sensor and it adjust to that? Is there a magic number it has built into it? And where in the WIN-PV system can I see the changes and compare?
Once you have run the Auto Tune, you will save the changes to a tune on the PV and flash it to the ECM.
You can then connect the PV to you computer and Under the PowerVision menu in WINPV you can "get tune from PowerVision". Then save the tune to the computer with a descriptive file name. You can then choose "load Compare" and select your Stock tune, WinPV will show you the differences in the VE Tables when you select "delta" on the menu.
DynoJet Guides
AutoTune- http://www.powercommander.com/downlo...utoTune.02.pdf
WinPV- http://www.powercommander.com/downlo...8100016.08.pdf
DynoJet Guides
fuelmoto
Fuel Moto / Jackpot Mufflers
08-08-2018 04:39 PM
rwt
40
08-05-2015 07:54 PM
